[PROJ] Defining a WKT CRS with a custom grid shift file
Even Rouault
even.rouault at spatialys.com
Fri Dec 13 05:17:11 PST 2019
Peter,
> I am working with custom CRS transformations using cs2cs. For typical EPSG
> codes, this works well, but I now want to support custom grid shift files
> that are not listed in proj.db. I currently am unsure how to do this with
> WKT strings.
> I want to describe the following two types of transformations:
> 1.
> Transform from horizontal CRS EPSG:XXXX to EPSG:4979 using yyyyy.gsb to
> transform heights
> 2.
> Transform from EPSG:4979 to EPSG:XXXX using yyyyy.gsb to transform
> heights
> Where yyyyy.gsb is a custom grid shift file. Is there a way to do this
> using a COMPOUNDCRS like the following?
> COMPOUNDCRS[“User-Defined Projection”,
> <WKT for horizontal CRS EPSG:XXXX>,
> VERTCRS[<whatever parameters are needed to specify yyyyy.gsb>]
If it is a .gsb file, then it is normally a horizontal shift, not a vertical
one. You shouldn't use a compoundCRs for that.
You can use a BoundCRS for that. Easy way to bootstrap one is to run
$ projinfo "+proj=longlat +ellps=GRS80 +nadgrids=foo.gsb +type=crs" \
-o WKT2_2019 -q
BOUNDCRS[
SOURCECRS[
GEOGCRS["unknown",
DATUM["Unknown based on GRS80 ellipsoid",
ELLIPSOID["GRS 1980",6378137,298.257222101,
LENGTHUNIT["metre",1],
ID["EPSG",7019]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8901]],
CS[ellipsoidal,2],
AXIS["longitude",east,
ORDER[1],
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]],
AXIS["latitude",north,
ORDER[2],
ID["EPSG",9122]]]]],
TARGETCRS[
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1]]],
ANGLEUNIT["degree",0.0174532925199433]],
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
ID["EPSG",4326]]],
ABRIDGEDTRANSFORMATION["unknown to WGS84",
METHOD["NTv2",
ID["EPSG",9615]],
PARAMETERFILE["Latitude and longitude difference file","foo.gsb",
ID["EPSG",8656]]]]
But if you just need it for cs2cs purposes, just use the above PROJ.4 style
string.
Otherwise if it is really a vertical shift (should rather be a .gtx file), use
"+proj=longlat +ellps=GRS80 +geoidgrids=foo.gtx +type=crs"
Even
http://www.spatialys.com
More information about the PROJ
