[PROJ] Deformation model format proposal - part 2
Chris Crook ccrook at linz.govt.nz
Sun Dec 15 23:22:21 PST 2019
Hi All
Thanks to all who have commented on the proposal for a new format for describing geodetic deformation models for time dependent coordinate transformations.
Based on the feedback I got I have now updated the proposal with some minor changes and a lot more detail about calculations methods.  The most significant change is using a JSON format for the deformation model master file (thanks to Kristian Evers and Jeremy Palmer for recommending this).
I propose to add more information on the New Zealand use case to this, but that will not alter the main content of the proposal around format and usage of the model.
So once again I welcome any further feedback before formally submitting this as an enhancement request to PROJ.
Thanks for any suggestions you have
Best Regards
Chris Crook
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the PROJ mailing list
