[PROJ] Defining a WKT CRS with a custom grid shift file
Even Rouault even.rouault at spatialys.com
Mon Dec 16 08:56:20 PST 2019
> Ah, I wasn’t aware of BOUNDCRS until now. To check my understanding, a
> BoundCRS is one where you input coordinates in SOURCECRS (x, y, z). Then
> when PROJ reads this in, it uses the ABRIDGEDTRANSFORMATION to convert to
> TARGETCRS (x’, y’, z’) which becomes the effective source CRS. This can
> then be converted +to some other CRS as usual. Is this an accurate
> description?
I'd say that when wanting to transform the (geographic CRS underlying the)
SOURECRS to TARGETCRS, then ABRIDGEDTRANSFORMATION is used.
> I also have a related follow-up question about some of the PROJ parameters.
> I now see that +geoidgrids=foo.gtx is for vertical shifts while
> +nadgrids=foo.gsb is for horizontal shifts. If this is the case, when would
> you use +proj=vgridshift +grids=foo.gtx?
+geoidgrids is a legacy syntax from the PROJ < 6 era when transformations
where put in CRS definitions.
+proj=vgridshift +grids=foo.gtx is an operation part of a coordinate
transformation pipeline to convert between CRS.
http://www.spatialys.com
More information about the PROJ mailing list
