[PROJ] test failure with 6.2.1
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Dec 29 22:08:16 PST 2019
On 12/30/19 3:56 AM, Greg Troxel wrote:
> Are tests of 6.2.1 expected to pass?  With the following grids, or
> something else?
The tests are expected to pass with only the grids from proj-datumgrid
available, when also adding grids from the regional archives you should
expect failures like these.
> This is with the following grids included:
>                 proj-datumgrid-1.8${EXTRACT_SUFX} \
>                 proj-datumgrid-europe-1.4${EXTRACT_SUFX} \
>                 proj-datumgrid-north-america-1.2${EXTRACT_SUFX} \
>                 proj-datumgrid-oceania-1.0${EXTRACT_SUFX} \
>                 proj-datumgrid-world-1.0${EXTRACT_SUFX}
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
