[PROJ] Odd 6.3.0RC1 issue
Even Rouault even.rouault at spatialys.com
Mon Dec 30 08:57:29 PST 2019
> Speculation, does using SetAxisMappingStrategy(OAMS_TRADITIONAL_GIS_ORDER)
> make a difference?
No, this is only used by GDAL for coordinate reprojection. No impact normally
on PROJ4 string export
> Anyway, rgdal is definitely broken with 6.3.0RC1 with no +ellps=airy term,
> and no +units=m term after exportToProj4(). What is the name of +ellps to
> use with GDALs OGRSpatialReference GetAttrValue()?
You can't. GetAttrValue() is about asking value of WKT(1) nodes, of PROJ.4
string
I suggest that you try to do a minimal .c/.cpp reproducer using only GDAL API
to identify if the issue is in GDAL/PROJ or in your code.
Even
http://www.spatialys.com
More information about the PROJ mailing list
