[PROJ] Right way to do this transformation/projection : ITRF2014 -> WGS84 UTM
Greg Troxel
gdt at lexort.com
Mon Dec 30 15:59:12 PST 2019
Even Rouault <even.rouault at spatialys.com> writes:
. On lundi 30 décembre 2019 13:04:50 CET Julien Schroder wrote:
> Hum, doesn't make sense to me. Can you demonstrate this with PROJ command line
> utilities ?
>> Which surprised me as I thought that going from ITRF2014 to WGS84 involved
>> a step through ITRF2000.
Careful - I think you mean "from ITRF2014 to WGS84(G1762)". Each WGS84
realization has a separate relationship to various ITRF and NAD83. I
am not clear if this link is fully correct (although I suspect it is):
https://www.e-education.psu.edu/geog862/node/1804
One of the earlier WGS84 realizations seems equivalent to ITRF2000.
> How did you see that ? In the above, the first result, which has worldwide
> validity, goes from ITRF2014 to WGS 84 (G1762) through ITRF2008. Because there
> is no direct transformation between ITRF2014 and WGS 84 (G1762) in the EPSG
> dataset (I presume the reason is that WGS 84 (G1762) must have been defined
> from ITRF2008)
It seems that WGS84(G1762) is defined by station coordinates at a number
of sites that also help to define ITRF2008. This paper has the details
(and a reference that I have not looked for yet, but seems interesting).
https://www.unoosa.org/pdf/icg/2016/icg11/wgd/02wgd.pdf
> (*) well, this isn't completely true. If you try
> projinfo -s ITRF2014 -t WGS84 --spatial-test intersects --summary
> with latest PROJ 6.3, you'll get not-null transformations in the USA in the
> Gulf of Mexico, but I think they are questionable as they involve a lot of
> hoops through other CRS such as ITRF2008, NAD83(2011), NAD83 and NAD27 ! This
> is due to latest EPSG database having a complex NAD27->ITRF2014 concatenated
> operation for Gulf of Mexico (using the NAD83, NAD83(2011) and ITRF2008
> intermediates), and thus it is chained with transformations from NAD27 to
> WGS84...
Wow!
More information about the PROJ
