[PROJ] Simple cs2cs in code
Even Rouault even.rouault at spatialys.com
Sat Feb 9 02:02:14 PST 2019
On vendredi 8 février 2019 12:25:11 CET Paul Ramsey wrote:
> I'm embarrassed to ask this, but looking at fixing up the postgis
> transform code to use the new API, I have
> pj_transform(srcpj, dstpj, 1, 0, &(pt->x), &(pt->y), &(pt->z))
> and I cannot for the life of my figure out how to replicate that in
> the new API...
> If I was instantiating a *PJ from an epsg:from and epsg:to, I would be
> fine, because there's the lovely proj_create_crs_to_crs function.
> But that's not the contract I have to fulfill. I have to fulfill a
> transform from_projstr to to_projstr. In generality. For a happy
> future, I'll also add some stuff to use proj_create_crs_to_crs where
> the metadata we have supports that call (which happily is in most
> cases). But in the fraught present, I still need to support the
> from_projstr, to_projstr pattern.
> I see I can use proj_create to go from a trom_projstr to a from_PJ,
> that's nice. And I can also make a to_PJ. But I don't see a way to
> call with a from and to.
> That leaves me wondering if I can just string concatenate a
> from_projstr and a to_projstr into a pipeline, get a PJ from that
> using proj_create, and call a forward transformation on that?
> Which still leaves my trying to create and test proj pipelines, which
> I have so far failed to do... the generic case being "a projected
> system on spheroid X to a different system on spheroid Y".
> I'm sorry if it's obvious and I"m looking at the wrong page :(
Paul,
With PROJ 5, yes creating a simple pipeline is the solution. So you can use
PJ* P = proj_create(ctxt,
	"+proj=pipeline +step +inv " + from_projstr + " +step " + to_projstr)
and use proj_trans(P, PJ_FWD, coord) afterwards
That's how current GDAL versions ported from the pj_transform() API to the new
one.
With PROJ 6, proj_create_crs_to_crs() has been extended to support PROJ CRS
strings or WKT CRS as arguments in addition to EPSG:XXXX codes.
Even
http://www.spatialys.com
More information about the PROJ mailing list
