[PROJ] Rads/Degs
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Feb 13 23:33:06 PST 2019
> > > the angular unit of the source (resp target) CRS, which will generally be
> > > degrees (except a few ancient French SRS that take grads)
For the right historical perspective it is better to describe the gon/grad CRS as "French revolutionary", since the French monarchy that was overtrown by the revolution is refered to as "ancien régime" and it were the revolutionaries that gave us the gon (and the metre).
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190214/96810ed4/attachment.html>
More information about the PROJ
