[PROJ] Vertical Transformations?
Andrew Bell andrew.bell.ia at gmail.com
Wed Feb 20 06:14:58 PST 2019
On Wed, Feb 20, 2019 at 9:06 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 20 février 2019 08:12:34 CET Greg Troxel wrote:
> > Even Rouault <even.rouault at spatialys.com> writes:
> > > With the vertconc.gtx grid available, you'll get
> > > $ echo "45 -100 100" | cs2cs -f "%.8f" EPSG:7406 EPSG:5500
> > > 44.99998071 -100.00039555 30.85853056
> > > Without it, you'll get just us-ft to metre for the vertical part:
> > > 44.99998071 -100.00039555 30.48006096
> > With the grids being in separate distribution files, it seems easy to
> > end up with them not installed.
> Yes, but as the number of grids is growing over time, putting them in a
> single
> package would be an annoyance for people who have local needs.
People have so much bandwidth and space now...
Perhaps it would be good to have the default be everything and allow a
reduced set to be available for those who need that?
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190220/2b4dd222/attachment.html>
More information about the PROJ mailing list
