[PROJ] Vertical Transformations?
Even Rouault
even.rouault at spatialys.com
Wed Feb 20 11:06:55 PST 2019
On mercredi 20 février 2019 13:25:07 CET Greg Troxel wrote:
> Even Rouault <even.rouault at spatialys.com> writes:
> > We could enhance the PROJ database with a table/column to flag required
> > transformation, but it is probably not trivial (area of use comes into the
> > equation), and that would put the PROJ project in a position of being an
> > "authority" to decide which transformation are required or not.
> That sounds like a good path.
> I don't see the authority problem; when implementing a transformation
> that is defined to use a grid file, it's pretty clear that it can't be
> done the same way without it.
For horizontal datum transformations, EPSG has generally both grid-based and
Helmert-based transformations. Which are both declared as valid. Generally the
grid-based one will have a better declared accuracy, so might be prefered. But
that doesn't invalidate the Helmert-based one. Failing if the grid is not
available would be a PROJ specific policy, and not always desirable.
http://www.spatialys.com
More information about the PROJ
