[PROJ] PROJ 6.0.0RC1
Kristian Evers kreve at sdfe.dk
Thu Feb 21 07:55:02 PST 2019
Hi Marco,
Yes, while it looks suspicious it is expected. Those errors are a issued when we are testing if PROJ issues the expected errors when initializing erroneous transformations.
We should probably turn the logging to STDOUT off in in this instance. If I can find the time for it tomorrow morning I will make that change in time for PROJ 6RC2 (which I plan on sending out tomorrow afternoon CET).
/Kristian
-----Oprindelig meddelelse-----
Fra: PROJ <proj-bounces at lists.osgeo.org> På vegne af Marco Atzeri
Sendt: 21. februar 2019 15:26
Til: proj at lists.osgeo.org
Emne: Re: [PROJ] PROJ 6.0.0RC1
Am 16.02.2019 um 08:48 schrieb Kristian Evers:
> All,
> I have prepared a release candidate of PROJ 6.0.0. See the release notes below.
Hi Kristian,
on cygwin 64 bit , I see no test failures, but I would like to know if
belows errors are expected
Reading file
'/pub/devel/proj/prova/proj-6.0.0-0.1.x86_64/src/proj-6.0.0/test/gie/GDA.gie'
total:  3 tests succeeded,  0 tests skipped,  0 tests failed.
proj_create: Error -47: illegal axis orientation combination
proj_create: Error -55: lat_0 = 0
proj_create: Error -9: unknown elliptical parameter name
proj_create: Error -13: major axis or radius = 0 or not given
proj_create: unrecognized format / unknown name
Reading file
'/pub/devel/proj/prova/proj-6.0.0-0.1.x86_64/src/proj-6.0.0/test/gie/axisswap.gie'
total: 27 tests succeeded,  0 tests skipped,  0 tests failed.
Regards
Marco
Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
https://www.avast.com/antivirus
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
