[PROJ] PROJ 6.0.0RC3
Even Rouault
even.rouault at spatialys.com
Tue Feb 26 01:53:49 PST 2019
Greg,
> Here is the build failure. It seems to be only mutex.cpp, so far.
> - I am unclear on all the -f and -W options and what they might cause.
I don't think they matter much here
> - There is no "--std=c++11".
That's a weird one. I do have g++ 5.5 on Ubuntu 16.04 and it defaults to
C++98, but ./configure automatically adds -std=c++11
But it would be strange that mutex.cpp is the only file to fail compilation.
C++11 is used extensively even in proj_internal.h, so all files should fail
compilation.
Are you absolutely sure that your "c++" binary is g++ 5.5 ?
What does the following return ?
c++ -dM -E -x c++ /dev/null | grep -F __cplusplus
If that's indeed the only file to fail compilation, I'd suggest you try
tweaking the start of the file to comment out the #define _XOPEN_SOURCE 500
and/or #define _GNU_SOURCE
Even
http://www.spatialys.com
More information about the PROJ
