[PROJ] PROJ 6.0.0RC3
Even Rouault
even.rouault at spatialys.com
Tue Feb 26 07:09:02 PST 2019
> (The machine also has gcc 6 installed, in a different prefix, but no older
> versions.)
> I would hope that proj builds ok with gcc 4.8; haven't tried yet.
It does.
> > If that's indeed the only file to fail compilation, I'd suggest you try
> > tweaking the start of the file to comment out the #define _XOPEN_SOURCE
> > 500
> > and/or #define _GNU_SOURCE
> That was the only one. It makes sense then that the --std flag is not
> the issue. Thanks for those hints - I had forgotten about
> _XOPEN_SOURCE, but now that I remember about definition visibility
> controls it sounds promising.
> Has anyone built proj 6 with clang? Any success reports from other than
> Linux?
It is built on different number of configurations in
https://travis-ci.com/OSGeo/proj.4/
and
https://travis-ci.com/OSGeo/gdal
Including clang and macosx
Windows Visual Studio builds also per
https://ci.appveyor.com/project/OSGeo/proj-4/history
http://www.spatialys.com
More information about the PROJ
