[PROJ] Announcing PROJ 6.1.1
Kristian Evers
kreve at sdfe.dk
Mon Jul 1 00:25:00 PDT 2019
On behalf of the PROJ development team I am happy to announce the
release of PROJ 6.1.1. This release is a patch release which fixes
9 bugs and updates the EPSG database to the most recent version.
See release notes below for details.
Download the source distribution here:
https://download.osgeo.org/proj/proj-6.1.1.tar.gz
https://download.osgeo.org/proj/proj-6.1.1.zip
6.1.1 Release Notes
Updates
o Update EPSG registry to version 9.6.3 (1485)
Bug Fixes
o Take the passed authority into account when identifying
objects (#1466)
o Avoid exception when transforming from NAD83 to projected
CRS using NAD83(2011) (#1477)
o Avoid off-by-one reading of name argument if name of resource
file has length 1 (#1489)
o Do not include PROJ_LIB in proj_info().searchpath when context
search path is set (#1498)
o Use correct delimeter for the current platform when parsing
PROJ_LIB (#1497)
o Do not confuse 'ID74' CRS with WKT2 ID[] node (#1506)
o WKT1 importer: do case insensitive comparison for axis
direction (#1509)
o Avoid compile errors on GCC 4.9.3 (#1512)
o Make sure that pipelines including +proj=ob_tran can be
created (#1526)
THANKS TO
Version 6.1.1 is made possible by the following contributors:
Alan D. Snow
Paul Menzel
Mateusz Ĺoskot
Bas Couwenberg
Peter Limkilde Svendsen
Mike Taves
Howard Butler
Nyall Dawson
Andrew Bell
Kristian Evers
Even Rouault
More information about the PROJ
