[PROJ] Precedence of multiple vertical grids
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Fri Jun 7 04:39:19 PDT 2019
After the PROJ. tutorial at the EUREF symposium I got started with PROJ.6. I'm very happy, as this solves many of my problems with introducing a new national transformation for the Netherlands. However, I do notice some odd behaviour now and then. This is the first one.
The order of precedence of vertical grids in PROJ. seems not to work as described in the documentation (https://proj.org/operations/transformations/vgridshift.html?highlight=gridshift):
(base) D:\>cct +proj=pipeline +step +proj=vgridshift +grids=D:\nlgeo2018beta.gtx,null
5 52 43
5.0000000000 52.0000000000 43.0000 inf
0 0 43
0.0000000000 0.0000000000 43.0000 inf
^Z
(base) D:\>cct +proj=pipeline +step +proj=vgridshift +grids=null,D:\nlgeo2018beta.gtx
5 52 43
5.0000000000 52.0000000000 -0.4754 inf
0 0 43
^Z
Confusingly, for horizontal grid shifts PROJ. does work as described in the documentation:
(base) D:\>cct +proj=pipeline +step +proj=hgridshift +grids=D:\rdtrans2018beta.gsb,null
5 52 43
4.9996207144 51.9990307906 43.0000 inf
0 0 43
^Z
(base) D:\>cct +proj=pipeline +step +proj=hgridshift +grids=null,D:\rdtrans2018beta.gsb
5 52 43
0 0 43
^Z
I tend to say that the documentation and the horizontal grid shift are correct and that the code for the vertical grid shift should be adapted?
Kind regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190607/3e693879/attachment.html>
More information about the PROJ
