[PROJ] PROJ 6.1.1RC1
Kristian Evers kreve at sdfe.dk
Sun Jun 23 11:38:50 PDT 2019
All,
With a scheduled release of PROJ 6.1.1. on July 1st it is time to put out a
release candidate.
Download the archives here:
https://download.osgeo.org/proj/proj-6.1.1RC1.tar.gz (https://download.osgeo.org/proj/proj-6.1.1RC1.tar.gz.md5)
https://download.osgeo.org/proj/proj-6.1.1RC1.zip    (https://download.osgeo.org/proj/proj-6.1.1RC1.zip.md5)
Please test the release candidate and report back any problems you
may encounter. See the release notes below.
/Kristian
6.1.1 Release Notes
 Updates
 o Update EPSG registry to version 9.6.3 (1485)
 Bug Fixes
 o Take the passed authority into account when identifying
   objects (#1466)
 o Avoid exception when transforming from NAD83 to projected
   CRS using NAD83(2011) (#1477)
 o Avoid off-by-one reading of name argument if name of resource
   file has length 1 (#1489)
 o Do not include PROJ_LIB in proj_info().searchpath when context
   search path is set (#1498)
 o Use  correct delimeter for the current platform when parsing
   PROJ_LIB (#1497)
 o Do not confuse 'ID74' CRS with WKT2 ID[] node (#1506)
 o WKT1 importer: do case insensitive comparison for axis
   direction (#1509)
 o Avoid compile errors on GCC 4.9.3 (#1512)
 o Make sure that pipelines including +proj=ob_tran can be
   created (#1526)
 THANKS TO
 Version 6.1.1 is made possible by the following contributors:
 Alan D. Snow
 Paul Menzel
 Mateusz Łoskot
 Bas Couwenberg
 Peter Limkilde Svendsen
 Mike Taves
 Howard Butler
 Nyall Dawson
 Andrew Bell
 Kristian Evers
 Even Rouault
More information about the PROJ mailing list
