[PROJ] Read vertical deflection from egm (96, 08, etc.)
Fabian Gross
F.Gross at sbp.de
Wed Jun 26 07:13:27 PDT 2019
Dear proj-members,
is there a way to read the vertical deflection (xi, eta) directly with
proj?
My work-around is sampling the geoid-grid shift:
```python
def get_vertical_deflection(lon, lat):
take origin and 1 east + 1 north on GEOID, transform to topocentric
and check
:param lon: longitude of point of interest on WGS84 (°)
:param lat: latitude of point of interest on WGS84 (°)
:return: (xi, eta) deflection in meridional and prime vertical (rad)
eps = 0.0001 # °
lons = np.array([lon, lon + eps, lon])
lats = np.array([lat, lat, lat + eps])
geoid_heights = get_geoid_height_egm96(lons, lats)
# W. E. Featherstone, "The Use and Abuse of Vertical Deflection" p. 4
e = eccentricity(f_wgs84)
phi = np.deg2rad(lat)
# meridional, north/south
# R_M, should be radius of curvature in the meridian at point of
interest
rad_meridian = get_radius_of_curvature_meridian(a_wgs84, e, phi)
# d_North = R d_lat; in rad
xi = -(geoid_heights[2] - geoid_heights[0])/(rad_meridian *
np.deg2rad(eps))
# prime vertical, east/west
# R_N, should be radius of curvature in the prime vertical at point of
interest
rad_prime_vertical = get_radius_of_curvature_prime_vertical(a_wgs84,
e, phi)
# d_East = R cos(lat) d_long; in rad
eta = -(geoid_heights[1] - geoid_heights[0])/(rad_prime_vertical *
np.deg2rad(eps) * np.cos(phi))
return xi, eta
Over which (arc) distance should I sample the geoid gtx?
Kind regards
Fabian Gross
Telefon +49 (711) 648 71-995
_________________________________________________
sbp
schlaich
bergermann partner
Beratende Ingenieure
für erneuerbare Energie
Stuttgart . Berlin . New York
São Paulo . Shanghai . Paris
sbp sonne gmbh
Markus Balz Dipl.Ing. (FH)
Andreas Keil Dipl.Ing.
Schwabstrasse 43
70197 Stuttgart
Telefon +49 (711) 648 71-0
www.sbp.de
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190626/9deae0d7/attachment.html>
More information about the PROJ
