[PROJ] GOES Geostationary Projection
Kurt Schwehr schwehr at gmail.com
Wed Jun 26 14:52:44 PDT 2019
Hi all,
I'm trying to figure out how to convert GOES 16 & 17 weather data into a
form readable by GeoTools.  It looks like I'm possibly loosing the sweep
information.  Take for example this set of 16 bands:
gsutil cp
gs://gcp-public-data-goes-17/ABI-L1b-RadC/2019/151/21/OR_ABI-L1b-RadC-*_G17_s20191512131197_*.nc
if I do:
gdalwarp --version
GDAL 2.2.4, released 2018/03/19
# e.g. for all C1..C16
gdalwarp -t_srs EPSG:4326
NETCDF:OR_ABI-L1b-RadC-M6C16_G17_s20191512131197_e20191512133581_c20191512134014.nc:Rad
OR_ABI-L1b-RadC-M6C16_G17_s20191512131197_e20191512133581_c20191512134014_4326.tif
The imagery once tiled by and displayed by Earth Engine, it shows up in the
correct location.
But I would rather have the data stay in it's native projection and only be
transformed when used to which ever projection is needed.  (this is typical
of Earth Engine)
gdal_translate
OR_ABI-L1b-RadC-M6C16_G17_s20191512131197_e20191512133581_c20191512134014.tif
Gives the imagery not quite in the correct location.   I briefly looked at
gdal_translate from proj at head and gdal at head, but our tiler is an
older version of gdal that can read the post "RFC 73: Integration of PROJ6
for WKT2" info.
Any one have suggestions on how to build a geotiff using gdal 2.2.4 from
the netcdf that keeps all the necessary projection info in a form that
GeoTools 19 can understand?
I've attached a screenshot from the Gulf of California where an island is
clearly offset between the renderings of the two assets (transformed from
the gdal_translate geotiff and the gdalwarp to EPSG:4326 geotiff)
Thanks!
-kurt
Engineer on Google Earth Engine
Earth Engine screen shots:
https://photos.app.goo.gl/sW1upk1iZ9p62MuY9
https://photos.app.goo.gl/UAGccF2rjPDfenS27
diff -u netcdf.info tif.info
--- netcdf.info 2019-06-26 10:54:22.512939636 -0700
+++ tif.info 2019-06-26 10:54:39.596731603 -0700
@@ -1,22 +1,23 @@
-Driver: netCDF/Network Common Data Format
-Files:
OR_ABI-L1b-RadC-M6C02_G17_s20191512131197_e20191512133570_c20191512133595.nc
+Driver: GTiff/GeoTIFF
+Files:
OR_ABI-L1b-RadC-M6C02_G17_s20191512131197_e20191512133570_c20191512133595.tif
 Size is 10000, 6000
 Coordinate System is:
-PROJCS["unnamed",
-    GEOGCS["unknown",
-        DATUM["unknown",
+PROJCS["Geostationary_Satellite",
+    GEOGCS["GCS_unknown",
+        DATUM["D_unknown",
             SPHEROID["Spheroid",6378137,298.2572221]],
         PRIMEM["Greenwich",0],
-        UNIT["degree",0.0174532925199433]],
+        UNIT["Degree",0.017453292519943295]],
     PROJECTION["Geostationary_Satellite"],
     PARAMETER["central_meridian",-137],
     PARAMETER["satellite_height",35786023],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
-    EXTENSION["PROJ4","+proj=geos +lon_0=-137 +h=35786023 +x_0=0 +y_0=0
+ellps=GRS80 +units=m +no_defs  +sweep=x"]]
+    UNIT["Meter",1]]
 Origin = (-2505021.493779813405126,1583173.639055640902370)
 Pixel Size = (501.004328871885207,501.004328871885264)
 Metadata:
+  AREA_OR_POINT=Area
   goes_imager_projection#grid_mapping_name=geostationary
   goes_imager_projection#inverse_flattening=298.2572221
   goes_imager_projection#latitude_of_projection_origin=0
@@ -81,23 +82,16 @@
   y#scale_factor=-1.4e-05
   y#standard_name=projection_y_coordinate
   y#units=rad
-Geolocation:
-  LINE_OFFSET=0
-  LINE_STEP=1
-  PIXEL_OFFSET=0
-  PIXEL_STEP=1
-  SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
-  X_BAND=1
 X_DATASET=NETCDF:"OR_ABI-L1b-RadC-M6C02_G17_s20191512131197_e20191512133570_c20191512133595.nc":x
-  Y_BAND=1
 Y_DATASET=NETCDF:"OR_ABI-L1b-RadC-M6C02_G17_s20191512131197_e20191512133570_c20191512133595.nc":y
+Image Structure Metadata:
+  COMPRESSION=DEFLATE
+  INTERLEAVE=BAND
 Corner Coordinates:
-Upper Left  (-2505021.494, 1583173.639) (161d34'43.88"W, 14d47'44.39"N)
-Lower Left  (-2505021.494, 4589199.612) (175d33' 0.44"E, 53d31'38.26"N)
-Upper Right ( 2505021.795, 1583173.639) (112d25'16.11"W, 14d47'44.39"N)
-Lower Right ( 2505021.795, 4589199.612) ( 89d33' 0.41"W, 53d31'38.26"N)
+Upper Left  (-2505021.494, 1583173.639) (161d33'27.65"W, 14d49'58.11"N)
+Lower Left  (-2505021.494, 4589199.612) (175d46'57.22"E, 53d43' 3.62"N)
+Upper Right ( 2505021.795, 1583173.639) (112d26'32.33"W, 14d49'58.11"N)
+Lower Right ( 2505021.795, 4589199.612) ( 89d46'57.19"W, 53d43' 3.62"N)
 Center      (       0.151, 3086186.626) (136d59'59.99"W, 29d58' 0.14"N)
-Band 1 Block=10000x1 Type=Int16, ColorInterp=Undefined
+Band 1 Block=10000x1 Type=Int16, ColorInterp=Gray
   NoData Value=4095
   Unit Type: W m-2 sr-1 um-1
   Offset: -20.2899112701416,   Scale:0.158592373132706
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190626/eae683d8/attachment.html>
More information about the PROJ mailing list
