[PROJ] GOES Geostationary Projection
Kurt Schwehr
schwehr at gmail.com
Thu Jun 27 10:29:21 PDT 2019
Thread on geotools-devel at lists.sourceforge.net here
https://sourceforge.net/p/geotools/mailman/message/36704682/
On Thu, Jun 27, 2019 at 10:08 AM Kurt Schwehr <schwehr at gmail.com> wrote:
> The GDAL in my tool chain is circa Oct-2018, so the hack. But since I'm
> writing a custom converter, I should be able to force the WKT to be what
> ever GeoTools wants for GEOS 16 & 17. I'll start up a discussion on the
> GeoTools mailing list and link back to here.
> On Thu, Jun 27, 2019 at 9:32 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On jeudi 27 juin 2019 08:43:06 CEST Kurt Schwehr wrote:
>> > Thanks Even!
>> > Since the end target isn't geotiff and it does have WKT
>> Which WKT are you talking about ?
>> I consider the WKT1 with PROJ strings you'll find reported by GDAL on the
>> netCDF or in GeoTIFF to be hack, but I don't know a standardized form of
>> WKT
>> for that.
>> With GDAL 3 / PROJ 6, the WKT2 is probably a bit better (see just below).
>> But
>> the method name and parameter names are still my own invention (hopefully
>> reasonable enough)
>> $ gdalsrsinfo "+proj=geos +sweep=x +h=35786023"
>> PROJ.4 : +proj=geos +sweep=x +lon_0=0 +h=35786023 +x_0=0 +y_0=0
>> +datum=WGS84
>> +units=m +no_defs
>> OGC WKT2:2018 :
>> PROJCRS["unknown",
>> BASEGEOGCRS["unknown",
>> DATUM["World Geodetic System 1984",
>> ELLIPSOID["WGS 84",6378137,298.257223563,
>> LENGTHUNIT["metre",1]],
>> ID["EPSG",6326]],
>> PRIMEM["Greenwich",0,
>> ANGLEUNIT["degree",0.0174532925199433],
>> ID["EPSG",8901]]],
>> CONVERSION["unknown",
>> METHOD["Geostationary Satellite (Sweep X)"],
>> PARAMETER["Longitude of natural origin",0,
>> ID["EPSG",8802]],
>> PARAMETER["Satellite Height",35786023,
>> LENGTHUNIT["metre",1,
>> ID["EPSG",9001]]],
>> PARAMETER["False easting",0,
>> LENGTHUNIT["metre",1],
>> ID["EPSG",8806]],
>> PARAMETER["False northing",0,
>> ID["EPSG",8807]]],
>> CS[Cartesian,2],
>> AXIS["(E)",east,
>> ORDER[1],
>> ID["EPSG",9001]]],
>> AXIS["(N)",north,
>> ORDER[2],
>> ID["EPSG",9001]]]]
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
> http://schwehr.org
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190627/db98a88d/attachment.html>
More information about the PROJ
