[PROJ] [GRASS-dev] GRASS GIS + PROJ 6 + GDAL 2.5
Markus Metz
markus.metz.giswork at gmail.com
Fri Mar 8 08:01:57 PST 2019
On Fri, Mar 8, 2019 at 12:41 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 8 mars 2019 12:27:37 CET Markus Metz wrote:
> > On Fri, Mar 8, 2019 at 10:49 AM Roger Bivand <Roger.Bivand at nhh.no>
wrote:
> > > Since rgdal::make_EPSG() is facing the same problems of listing
tabulated
> > > EPSG fields as g.proj -l, I was very happy to see Markus' code in
> > > g.proj/main.c mentioned in this thread, and have used this approach in
https://r-forge.r-project.org/scm/viewvc.php/pkg/src/proj_info6.cpp?view=mar
> > kup&root=rgdal
> > > However, there are plenty of messages such as: "proj_as_proj_string:
> > > Unsupported conversion method: Lambert Conic Conformal (West
> > Orientated)". I
> > > haven't installed GRASS trunk with PROJ6, so I can't see whether
g.proj -l
> > > also sees the same messages.
> > I get the same messages with g.proj, but no error code from PROJ error
> > handlers.
> > > If it does, maybe we could ask on the proj list
> > yes, we should ask. For now g.proj is ignoring those codes for which no
> > proj string can be retrieved.
> I'm not sure what the question is exactly :-)
My question is, what should GRASS do with a SRS without proj string? The
best answer is probably: use WKT instead of a proj string. But most of the
GRASS code uses (for historical reasons) some form of proj syntax, also to
store projection info for a GRASS location. If there is no proj string,
GRASS thinks there is no SRS and falls back to a generic xy system which is
not always correct.
Markus M
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190308/062341fd/attachment-0001.html>
More information about the PROJ
