[PROJ] PROJ 6.0.0 cs2cs: cannot instantiate source coordinate system - program abnormally terminated
Even Rouault
even.rouault at spatialys.com
Fri Mar 8 09:17:26 PST 2019
On vendredi 8 mars 2019 16:28:07 CET Sebastiaan Couwenberg wrote:
> The cs2cs tests in the proj-rdnap package [0] fail with PROJ 6.0.0:
> Rel. 6.0.0, March 1st, 2019
> <cs2cs>:
> cannot initialize transformation
> cause: (null)
> The problem seems to be the minimal epsg file in PROJ_LIB, removing is
> works around the issue.
> Should cs2cs really terminate abnormally when an problematic init file
> is present in PROJ_LIB?
Actually, this is rather subtle. The issue is that the definition of epsg:4258
in the minimum epsg file is interpretated as a Geographic 2D CRS, whereas
rdnap:rdnap is interpretated as as CompoundCRS (horizontal + vertical).
Normally the code that computes the possible transformation paths would find a
Geographic 3D CRS that corresponds to the Geographic 2D CRS, but in the case
of a '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs' definition,
there's no single such 3D CRS. So no transformation path is returned at all.
When using the EPSG:4258 definition from proj.db, then the EPSG:4937 (ETRS89
3D) is used internally.
Even
http://www.spatialys.com
More information about the PROJ
