[PROJ] Proj 6 API questions
Even Rouault
even.rouault at spatialys.com
Mon Mar 18 04:18:08 PDT 2019
> I guess name should have a unique constraint if we were to guarantee unique
> names.
There is no guarantee that names are uniques, the EPSG database table
declaration has no such guarantee itself, and we mix data from different
authorities.
Only the tuple (auth_name, code) is guaranteed to be unique.
Actually in the proj.db, there are dupllicated names, like the following
(after a fix I've just done since the code for the ESRI object was incorrect)
OGRFeature(SELECT):0
auth_name (String) = EPSG
code (String) = 1024
name (String) = CGCS2000
description (String) = (null)
celestial_body_auth_name (String) = PROJ
celestial_body_code (String) = EARTH
semi_major_axis (Real) = 6378137
uom_auth_name (String) = EPSG
uom_code (String) = 9001
inv_flattening (Real) = 298.257222101
semi_minor_axis (Real) = (null)
deprecated (Integer) = 0
OGRFeature(SELECT):1
auth_name (String) = ESRI
code (String) = 107038
description (String) = China Geodetic Coordinate System 2000
deprecated (Integer) = 1
Even
http://www.spatialys.com
More information about the PROJ
