[PROJ] Proj 6 API questions
Even Rouault
even.rouault at spatialys.com
Mon Mar 18 04:56:57 PDT 2019
> > OGRFeature(SELECT):1
> > description (String) = China Geodetic Coordinate System 2000
> > celestial_body_code (String) = EARTH
> What api can I use to get the description and celestial body for an
> ellipsoid?
There's no API for that. description is mostly a provisional field, not set
for EPSG data (it is set for ESRI data though). And celestial body was also a
provision for which there's no C API
Even
http://www.spatialys.com
More information about the PROJ
