[PROJ] Proj 6 API questions
Nyall Dawson nyall.dawson at gmail.com
Wed Mar 20 15:50:37 PDT 2019
On Tue, 19 Mar 2019 at 15:36, Kristian Evers <kreve at sdfe.dk> wrote:
> From the projinfo docs:
> "where {object_definition} or {object_definition} is a PROJ string, a WKT string,
> an object name or a AUTHORITY:CODE (where AUTHORITY is the name of a
> CRS authority and CODE the code of a CRS found in the proj.db database)."
> You are giving a authority:code combination so it is only looking for a CRS. With
> the -k switch you can change that behaviour to look for a operation instead.
> Maybe there’s a need for more options to the -k switch? Like ellipsoid, axis, AoU
> and so on?
A -k ellipsoid option is added here:
https://github.com/OSGeo/proj.4/pull/1338
Nyall
More information about the PROJ mailing list
