[PROJ] [EXTERNAL] Re: Proj 6 API questions
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Tue Mar 26 00:56:55 PDT 2019
> I honestly don't have any plans to change this behavior. I cannot see
> a way to remove this choice from users, as QGIS projects don't have a
> single CRS, but they DO need a single ellipsoid. The best we can do is
> make sure that a good default selection is given to users, but we
> cannot totally remove this choice.
To add a 3rd opinion in the debate: I think the ellipsoid should should NOT automatically be set to the ellipsoid of a CRS used by the user, but it should by default kept set to GRS80, unless the user explicitly manually selects another ellipsoid. GRS80 is scientifically the best ellipsoid, all others are outdated (not the most accurate estimation of the size of the earth), unconventional (seldomly used) or wrong (e.g. due to rounding of parameters). The only exception would be extra-terrestrial CRSs: there GRS80 make no sense and the scientifically best ellipsoid of the planet in question should be selected by default. When a user is using a national CRS based on a old ellipsoid, (s)he mostly doesn't want distances and areas based on this outdated ellispoid but distances and areas computed in the best way possible, which is GRS80.
Kind regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ
