[PROJ] [EXTERNAL] Re: Proj 6 API questions
Nyall Dawson
nyall.dawson at gmail.com
Tue Mar 26 18:28:10 PDT 2019
On Tue, 26 Mar 2019 at 20:57, Even Rouault <even.rouault at spatialys.com> wrote:
> On mardi 26 mars 2019 19:56:22 CET Nyall Dawson wrote:
> > On Tue, 26 Mar 2019 at 17:58, Lesparre, Jochem
> > <Jochem.Lesparre at kadaster.nl> wrote:
> > > > I honestly don't have any plans to change this behavior. I cannot see
> > > > a way to remove this choice from users, as QGIS projects don't have a
> > > > single CRS, but they DO need a single ellipsoid. The best we can do is
> > > > make sure that a good default selection is given to users, but we
> > > > cannot totally remove this choice.
> > > To add a 3rd opinion in the debate: I think the ellipsoid should should
> > > NOT automatically be set to the ellipsoid of a CRS used by the user, but
> > > it should by default kept set to GRS80, unless the user explicitly
> > > manually selects another ellipsoid. GRS80 is scientifically the best
> > > ellipsoid, all others are outdated (not the most accurate estimation of
> > > the size of the earth), unconventional (seldomly used) or wrong (e.g. due
> > > to rounding of parameters). The only exception would be extra-terrestrial
> > > CRSs: there GRS80 make no sense and the scientifically best ellipsoid of
> > > the planet in question should be selected by default. When a user is
> > > using a national CRS based on a old ellipsoid, (s)he mostly doesn't want
> > > distances and areas based on this outdated ellispoid but distances and
> > > areas computed in the best way possible, which is GRS80.
> > I'm very much in favour of this approach!
> The question raised by Kristian is still valid. How do you convert from
> project coordinates to coordinates on the measurement ellipsoid ?
> - is is a no-op conversion, that is
> lon,lat(measurement_ellipsoid) = lon,lat(project_crs) ?
> That would be wrong.
> - or some form of coordinate transformation from the project CRS to the
> measurement ellipsoid, but then you'll get no datum shifts. That said, for
> measurement, that probably doesn't make a lot of difference in the resulting
> computation (assuming that the shift would be almost homogeneous on the area
> of interest)
See earlier in this thread -- it's the second, we reproject from the
layer coordinates to a "+proj=longlat +a=%1 +b=%2 +no_defs" or
"+proj=longlat +a=%1 +rf=%2 +no_defs" definition.
> > I wonder if this is something which belongs in the proj db itself.
> > I.e. some API to query the recommended ellipsoid for a given planetary
> > body.
> Before the API, we would need the information. The database doesn't store a
> concept of recommended ellipsoid. Could be a new column in 'ellipsoid' table
> with a check that there's a single recommended ellipsoid for a celestial_body,
> and that for each body, there's a recommended ellipsoid (commit.sql can be
> used to add consistency checks that don't fall in usual SQL constraints)
> (thinking out loud. haven't given that more thought)
That's exactly what I had in mind.
What's semi_major_axis in the celestial_body table used for? To me
this is basically a default ellipsoid definition for those bodies, but
bypassing the ellipsoid table. Maybe it makes sense to remove this
column?
Nyall
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the PROJ
