[PROJ] [EXTERNAL] Re: Proj 6 API questions
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Mar 27 03:53:40 PDT 2019
Kristian is right that just using a modern ellipsoid for distances/areas in an old but still used national CRS would give errors.
However, I think computing distances/areas using the old ellipsoid of that CRS is also not correct for most users. Therefore, I suggest:
1. Back-project the projected coordinates to geodetic coordinates using the Ellipsoid parameters of the CRS datum.
2. Perform datum transformation to the most recent realisation of the currently accepted scientific CRS of that planet (currently ITRF2014 for Earth) with its ellipsoid (currently GRS80 for Earth).
3. Perform geodesic calculations using this ellipsoid parameters of this CRS datum.
Kind regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ
