[PROJ] question about EPSG:3003
Even Rouault even.rouault at spatialys.com
Wed May 1 07:49:29 PDT 2019
Hi Sandro,
First, if you instanciate with proj_create() / proj_create_from_database() and
export with proj_as_proj_string(), you'll never get a towgs84 clause.
Since the CRS by itself has no transformation clause.
However if you look at the output of the projinfo utility or
OSRImportFromEPSG(), you may, sometimes, get a towgs84 clause when exporting
to PROJ string (e.g with EPSG:4322 / WGS72), because they use the
proj_crs_create_bound_crs_to_WGS84() function which tries to find the most
precise transformation from the CRS to EPSG:4326, and, that's the important
point, which is valid for the whole area of use of the CRS.
For EPSG:3003, there are however 3 possibilities (you can ignore the last one
in the below output), none of which cover the whole area of use of the
projected CRS.
$ src/projinfo -s EPSG:3003 -t EPSG:4326 --spatial-test intersects --summary
Candidate operations found: 4
unknown id, Inverse of Italy zone 1 + Monte Mario to WGS 84 (4), 4 m, Italy -
mainland
unknown id, Inverse of Italy zone 1 + Monte Mario to WGS 84 (2), 4 m, Italy -
Sardinia onshore
unknown id, Inverse of Italy zone 1 + Monte Mario to WGS 84 (11), 10 m, Italy
- Sicily Strait west of 13°E
unknown id, Inverse of Italy zone 1 + Ballpark geographic offset from Monte
Mario to WGS 84, unknown accuracy, World, has ballpark transformation
Previous PROJ version hard-coded the transformation that has the largest area
of use, but that's not necessarily ideal in all use cases (Sardinia or Sicily)
So, this is intended behaviour. I'm campaigning here and on all relevants
channels: "With PROJ 6, PROJ strings to express CRS are very suboptimal. They
should be restricted to express a transformation pipeline"
If you want Spatialite to have the same behaviour as before regarding
generation of PROJ strings, you could possibly use the
proj_create_operations() API to list the possible transformations, by setting
proj_operation_factory_context_set_spatial_criterion(PROJ_SPATIAL_CRITERION_PARTIAL_INTERSECTION)
on the factory_ctx, pickup the one that has the largest area of use, create
the final bound CRS with that transformation with proj_crs_create_bound_crs(),
and export it to a PROJ string.
Admitedly, we could have a releaxed proj_crs_create_bound_crs_to_WGS84()
implementation in PROJ itself to do that, but I'm not sure if we really need
to replicate/encourage past suboptimal behaviour.
Even
http://www.spatialys.com
More information about the PROJ mailing list
