[PROJ] PROJ 6.1.0RC1
Kristian Evers kreve at sdfe.dk
Mon May 6 01:08:44 PDT 2019
>From the previous thread it seems to be a difficult problem without a clear
Solution. Looking at the test output though it seems as if the vertical shift
isn't  applied. Whether that is because of the issues discussed previously or
it is a problem in finding the naptrans2008.gtx grid on the system I can't
tell from the log file.
The log file is also reporting that the epsg init file fails to load:
	pj_open_lib(epsg): call fopen(/usr/share/proj/epsg) - failed
So, is this simply an incorrect setting of PROJ_LIB or is it still the same
not so simple issue as reported previously?
/Kristian
-----Oprindelig meddelelse-----
Fra: PROJ <proj-bounces at lists.osgeo.org> På vegne af Bas Couwenberg
Sendt: 6. maj 2019 09:42
Til: proj at lists.osgeo.org
Emne: Re: [PROJ] PROJ 6.1.0RC1
[Resending with compressed attachment]
On 2019-05-06 08:24, Kristian Evers wrote:
> Please test the release candidates and report back any problems you
> may find.
The tests for the RDNAP datumgrid [0] still fail with 6.1.0-rc1.
The height values are exceed the allowed margin. See the attachment.
This is the biggest regression since PROJ 5.2.0 I've encountered.
[0] https://lists.osgeo.org/pipermail/proj/2019-March/008313.html
Kind Regards,
Bas
More information about the PROJ mailing list
