[PROJ] Getting "proj" and "datum" for a CRS
Kristian Evers
kreve at sdfe.dk
Tue May 7 05:48:41 PDT 2019
> On 7 May 2019, at 11:37, Even Rouault <even.rouault at spatialys.com> wrote:
>>> I'd note that adding a new member to PJ_PROJ_INFO will change the ABI in a
>>> incompatible manner. Will/would require a libtool 'current' bump
>> So is this a -1 on this change? I'm conscious the deadline is closing
>> for 6.1....
> I'm indifferent. Was mostly to bring that to the attention of Kristian.
Thanks :-) I am of the opinion that we should avoid incompatible changes for
this release. When suggested adding more to PJ_PROJ_INFO I didn’t realize
that it would affect the ABI.
In addition, after having giving this some more though I think there must be a
better way to deal with this problem. A generic function that can returns all
parameters that make up a PJ object would be preferable. A wrapper for
pj_param() would do the trick but a better way likely exists.
>> At the moment I'm wondering if I'll need to just resort to a regex to
>> get this property (argh!)
> In an ideal world, QGIS should avoid messing directly with PROJ strings (I
> guess this is for some backward compatibility reason regarding QGIS API).
> Especially regarding extracting elements from them. Treating the whole string
> as an opaque string might be acceptable, although not the most precise
> representation compared to using WKT or directly the EPSG:XXXX representation
> when available (I know I repeat myself on this, but this is for the education
> of the crowds :-))
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the PROJ
