[PROJ] Possible error with +datum=potsdam and PROJ >= 5.0.0
Even Rouault
even.rouault at spatialys.com
Tue May 7 12:52:12 PDT 2019
Actually, I realize there must be something fishy with your PROJ installation.
The BETA2007.gsb grid is part of the
https://download.osgeo.org/proj/proj-datumgrid-1.8.zip package which is
normally installed together with PROJ with usual binary distributions, so the
changed to expanding to +nadgrids=@BETA2007.gsb was reasonable.
If you compile PROJ from source, you must unzip its content in
${proj_install_prefix}/share/proj
> Alexander,
> In PROJ 4.9.3 and earlier, +datum=potsdam expanded to
> +ellps=bessel +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7
> In PROJ 5.0.0 and later, +datum=postdam was changed to expand to
> +ellps=bessel +nadgrids=@BETA2007.gsb
> That is it will use the more precise BETA2007.gsb grid rather than the
> towgs84 clause, but this require the grid to be installed alongside other
> PROJ grids. If not present, then no datum shift is done, hence the result
> you see.
> So with PROJ 5.0.0 and later, you could get the same result as PROJ 4.9.3 if
> you don't have the grid installed, by replacing "+datum=potsdam" with
> "+ellps=bessel +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7"
> (I don't understand why you'd get a correct result with just +ellps=bessel
> without a +towgs84 or +nadgrids. That doesn't make sense to me)
> With proj 5.2.0
> $ echo "4395886.918912 5819485.694352" | cs2cs -f "%.4f" +proj=tmerc
> +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
> +towgs84=598.1,73.7,418.2,0.202,0.045,-2.455,6.7 +to +init=epsg:25832
> 599474.7609 5817502.6096 42.5689
> With proj 6, things will work transparently:
> - with BETA2007.gdb installed, you get exactly the result from the .csv
> file:
> $ echo "4395886.918912 5819485.694352" | cs2cs -f "%.4f" EPSG:31464
> EPSG:25832 599474.9342 5817502.6270 0.0000
> - without it installed, it fallbacks to the Helmert transformation
> EPSG:25832 599474.7609 5817502.6096 0.0000
> Even
> > Hi,
> > we noticed differences in transforming geographic data from EPSG:31468
> > to WGS 84 using ST_Transform on different PostGIS installations and it
> > seems to come from different PROJ versions.
> > For example, we have a point from CAD drawings of the Nuremberg subway
> > network with the coordinates 4435877.4477166822 5475816.0547993957, so
> > we know it must be on the train tracks.
> > Converting this point using PROJ 4.9.3 gives us this point [1] with the
> > coordinates 11.1148165905971 49.4159011654427 and using PROJ 5.0.1
> > gives us this point [2] with the coordinates 11.1161576118633
> > 49.4169712194789. However, updating the proj4text in the
> > spatial_ref_sys table for the srid 31468 from
> > +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +datum=potsdam
> > +units=m +no_defs
> > to
> > +proj=tmerc +lat_0=0 +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +ellps=bessel
> > on the PostGIS installation with version 5.0.1 of PROJ again gives
> > correct results.
> > PROJ version >= 5.0.0 seems to incorrectly handle conversions using
> > +datum=potsdam. From [3] one can download test data to verify correct
> > conversion from DHDN / GK to ETRS89 / UTM. Testing conversion of the
> > value in line 7 of the downloadable CSV file [4] the results for PROJ
> > version 4.9.3 and versions >= 5.0.0 differ. I have executed the
> > following command using PROJ versions 4.9.3, 5.0.0, 5.1.0, and 6.0.0
> > echo 4395886.918912 5819485.694352 | cs2cs +proj=tmerc +lat_0=0
> > +lon_0=12 +k=1 +x_0=4500000 +y_0=0 +datum=potsdam +units=m +no_defs +to
> > +init=epsg:25832
> > The output for 4.9.3 is:
> > 599474.76 5817502.61 42.57
> > The output for the other versions is:
> > 599559.03 5817663.04 0.00
> > Is this a bug in PROJ? And if so, what would be the recommended
> > workaround?
> > Kind Regards,
> > Alexander Njemz
> > [1] https://www.google.de/maps/place/49%C2%B024'57.2%22N+11%C2%B
> > 006'53.3%22E/@49.4158889,11.1126169,751m/data=!3m2!1e3!4b1!4m5!3m4!1s0x
> > 0:0x0!8m2!3d49.4159012!4d11.1148166
> > [2] https://www.google.de/maps/place/49%C2%B025'01.1%22N+11%C2%B
> > 006'58.2%22E/@49.4169722,11.113978,750m/data=!3m2!1e3!4b1!4m5!3m4!1s0x0
> > :0x0!8m2!3d49.4169712!4d11.1161576
> > [3] http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/de_dhdn2etr
> > s_beta.php
> > [4] http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/BETA2007tes
> > tdaten.csv
http://www.spatialys.com
More information about the PROJ
