[PROJ] Motion: Promote 6.1.0RC3 to final release
Even Rouault
even.rouault at spatialys.com
Mon May 13 07:53:35 PDT 2019
On lundi 13 mai 2019 07:36:28 CDT Alan Snow wrote:
> It should be noted that proj_identify does not filter by auth_name (I
> raised an issue about that). Everything else works great 👍. So, if that
> capability is not a deal breaker, should be fine to proceed with the
> release.
I've just issued a pull request ( https://github.com/OSGeo/proj.4/pull/1466 )
to fix it.
I don't think that is a release blocker though. The bug was already in 6.0.
There will always been known and unknown bugs in any release we issue...
A possible workaround is to export the CRS to identify as a PROJ string,
create a new CRS object from it, and identify it by restricting to the EPSG
authoriy name (of course you'll loose some information). Or a bit better, but
more involved, export as WKT, remove the ID/AUTHORITY node, and identify.
Even
> On Mon, May 13, 2019, 7:00 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
> > On lundi 13 mai 2019 09:34:52 CDT Kristian Evers wrote:
> > > PSC Members,
> > > I hereby motion that PROJ 6.1.0RC3 be promoted to final release.
> > > The motion will be concluded May 15th.
> > > I'll start with my +1.
> > +1 Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > PROJ mailing list
> > PROJ at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
