[PROJ] Newbie question on projections
Alan Snow
alansnow21 at gmail.com
Thu May 23 10:54:27 PDT 2019
Depending on your end goal, I would recommend using GDAL to reproject 2D
data. This will resample your data from a 2D grid in one projection to a 2D
grid in a new projection.
https://www.gdal.org/gdalwarp.html
If you are a Python user, I would recommend:
https://corteva.github.io/rioxarray/html/examples/reproject.html
https://rasterio.readthedocs.io/en/stable/topics/reproject.html
Hopefully this helps,
Alan
On Thu, May 23, 2019 at 12:42 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Proj will convert double arrays of longitude/latitudes into Mollweide, if
> that’s the question? It’ll also convert into a whole zoo of other
> interesting global projections, if you’re looking for alternatives. It can
> be called as a library https://proj4.org/development/quickstart.html
> On May 23, 2019, at 10:14 AM, Daniel Suson <djsuson at gmail.com> wrote:
> I have a project that takes spherical maps (either Terrestrial or
> astronomical) as its input. The inputted data is stored in a "flat" 360x180
> (scaled up or down depending upon the resolution) 2-D array. As an early
> step in the process I then display the map in one of the basic projections
> (currently Mollweide, but I would like to support others). I am hoping that
> I can use PROJ4 to transform this into another 2-D array that can then be
> passed into the display routines.
> 1. Is this something that PROJ4 can do?
> 2. If so, can this capability be called as a library function from
> within the program?
> 3. If not, is there another library I should consider to support this
> need?
> Thank you for your help with this.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
Alan Snow
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20190523/d2e17827/attachment.html>
More information about the PROJ
