[PROJ] Error Building Docs
Even Rouault even.rouault at spatialys.com
Wed May 29 11:53:24 PDT 2019
On mercredi 29 mai 2019 14:19:11 CEST Andrew Bell wrote:
> I'm getting an error building the documentation:
> $ make dirhtml
> reading sources... [ 11%] development/reference/cpp/cpp_general
> Warning, treated as error:
> /Users/acbell/proj.4/docs/source/development/reference/cpp/common.rst:6:doxy
> gennamespace: Cannot find file:
> /Users/acbell/proj.4/docs/build/xml/index.xml
> Can someone tell me what I need to do to fix this?
Look at the 'html:' target in docs/Makefile. You probably need to replicate
the hacks done for it in the 'dirhtml:' target
http://www.spatialys.com
More information about the PROJ mailing list
