[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Even Rouault even.rouault at spatialys.com
Thu Nov 7 06:15:24 PST 2019
It has been reported that PROJ 6.2.1 (also applies to master) runs super slow
if used with a too old SQLite version (https://github.com/OSGeo/PROJ/issues/
1718). It works fine with SQLite 3.11 (as found on Ubuntu 16.04 for example).
SQLite 3.11 was released on 2016-02-15, so meets our "older than 2 years"
rule.
Hence the following motion
Require SQLite 3.11 for PROJ master
+1 Even
PR implementing this ready in https://github.com/OSGeo/PROJ/pull/1721
Will apply for PROJ 6.3
http://www.spatialys.com
More information about the PROJ mailing list
