[PROJ] PSC Motion: require SQLite 3.11 as minimum version
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Nov 7 07:43:02 PST 2019
+1
As a Windows packager (6,000+ downloads per month for the MapServer
community) we upgraded to minimum SQLite 3.17.0 for MS4W releases, as
that SQLite release has reported 25% performance boost through R-tree
indexing improvements.
-jeff
On 2019-11-07 10:15 AM, Even Rouault wrote:
> Hi,
> It has been reported that PROJ 6.2.1 (also applies to master) runs super slow
> if used with a too old SQLite version (https://github.com/OSGeo/PROJ/issues/
> 1718). It works fine with SQLite 3.11 (as found on Ubuntu 16.04 for example).
> SQLite 3.11 was released on 2016-02-15, so meets our "older than 2 years"
> rule.
> Hence the following motion
> Require SQLite 3.11 for PROJ master
> +1 Even
> PR implementing this ready in https://github.com/OSGeo/PROJ/pull/1721
> Will apply for PROJ 6.3
More information about the PROJ
