[PROJ] Management of datum grid files.
Even Rouault
even.rouault at spatialys.com
Tue Nov 26 14:12:20 PST 2019
> No. The PROJ binary has no idea where PROJ_LIB can be pointed too. That's
> why it is needed to be defined. For some builds typically done by Linux
> distributions where the installaton path is known at build time, the
> default search path is hardcoded in the binary, but for Windows, the actual
> installation path is rarely known in advance.
Yes, that's why I floated around the idea that PROJ default search path could
also include the ${XDG_DATA_HOME}/proj directory, where ${XDG_DATA_HOME}
resolves to ${HOME}/.local/share on Unix builds and ${USERPROFILE}/.local/
share on Windows builds, that RFC4 plans to use to put the local cache of
downloaded chunks from the CDN. That has also the advantage that it is a user
writable directory, which can help people not having admin rights.
Even
http://www.spatialys.com
More information about the PROJ
