[PROJ] EPSG (was: Code of conduct)
Martin Desruisseaux
martin.desruisseaux at geomatys.com
Fri Oct 18 10:39:38 PDT 2019
Note: my concern is only about EPSG dataset. Everything else in PROJ
look all clean for every parts I'm familiar with.
Le 18/10/2019 à 15:00, Howard Butler a écrit :
> Any activity from IOGP isn't going to change PROJ's project situation
> in regard to OSGeo incubation. While this is an issue to monitor, it
> isn't one to hold things up.
It depends if a graduation goal is to assert that PROJ is legally clean.
If yes, then I see this choice:
* PROJ can redistribute EPSG dataset under EPSG Terms of Use.
* If PROJ wants to relicense EPSG dataset (i.e. suppress EPSG Terms of
Use and put MIT license in place, which is my understanding of
ticket #2268 [1]), then we need IOGP explicit authorization. Most
OpenSource licenses do not allow relicensing neither (except by the
author); even the MIT license does not allow that (note: MIT allows
sub-licensing, but this is different than re-licensing).
If resolving legal issues is not a graduation goal, then indeed my
remark is not relevant to the graduation process.
Martin
[1] https://trac.osgeo.org/osgeo/ticket/2268
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20191018/3562af8d/attachment.html>
More information about the PROJ
