[PROJ] build failure with GCC 9.1.0
Even Rouault even.rouault at spatialys.com
Wed Sep 25 01:49:22 PDT 2019
> I am afraid it is not enough. Please find attached 4 additional patches :
>      - proj-6.2.0-hanato.gpatch and proj-6.2.0-mbtfpp.gpatch
> In files src/projections/hatano.cpp and src/projections/mbtfpp.cpp,
> change the CS define to CSz in order to avoid overriding the CS system
> definition
ok for those ones.
>      - proj-6.2.0-isea.gpatch :
> In file src/projections/isea.cpp, change the quad variable name as it is
> overriding another system definition
> $ grep quad  /usr/include/sys/types.h
> typedef struct _quad { int val[2]; } quad_t;    /* used by UFS */
> typedef quad_t          quad;                   /* used by UFS */
I'm quite surprised about that one. The compiler should be smart enough to see
that in "int quad;" quad is a variable name, not a struct. Which error message
do you get exactly ?
Can you try to compile the following test.cpp file ?
struct foo
    int quad;
int main()
    int quad = 0;
    return quad;
$ g++ -std=c++11 test.cpp -c
Works fine on Linux. If adding, -Wshadow, it will complain though about the
int quad = 0 shadowing the global declaration of typedef quad_t quad;
>      - proj-6.2.0-io.gpatch
It is essentially the same as my pull request, or am I missing somethig ?
> Note : I quite understood what I changed in the first 3 patches. Not
> sure in the last one. Can you please review it ?
Which one do you mean by the last one, the one for io.cpp ?
Even
http://www.spatialys.com
More information about the PROJ mailing list
