[PROJ] Calculating DTK25 from WGS84
Dominik Vogt dominik.vogt at gmx.de
Wed Apr 8 03:38:30 PDT 2020
Hi folks,
I have little knowledge of map projections and really need some
help with a coordinate transformation.
The source data is a long list of latitude/longitude pairs in
WGS84 (epsg:4326).  The goal is to calculate the corresponding
DTK25 map sheet.
DTK25 is a four digit number XXYY where
  XX = [(56 - lat) * 10]
  YY = [(lon - 5.66666666) * 6]
*But* DTK25 is based on the bessel ellipsoid.
What I cannot figure out is how to transform the latitude and
longitude from the wgs84 ellipsoid form to the bessel ellipsoid
form.  I've tried something like this:
  echo 49.12345 8.55555 |
  cs2cs +proj=latlon +ellps=WGS84 +to +proj=latlon +ellps=bessel -f "%.12f"
But it actually does nothing; output coordinates are unchanged.
Maybe I just don't understand how cs2cs works.
Ciao
Dominik ^_^  ^_^
Dominik Vogt
More information about the PROJ mailing list
