[PROJ] Linking proj as a static lib to a Windows application
Finn Arildsen
finn at arildsen.com
Wed Apr 8 08:35:00 PDT 2020
I'm working on integrating PROJ into my Windows application, and I have a
problem with uninitialzed static variables in the PROJ lib.
So far I have been able to build the PROJ lib using the supplied CMAKE
scripts. I have successfully linked the lib to my application, and I have
been able to call library functions. proj_context_create connects to the
sqlite database correctly etc.
However, the static objects in the PROJ library are never initialized -
constructors are never called, so eventually the library crashes in a call
to UnitOfMeasure::conversionToSI, because UnitOfMeasure::DEGREE is not
initialized.
I have successfully run the library test suite, and I can see that when
running the test programs in the debugger, the library static constructors
get correctly called from the run-time library's _initterm function (through
a list of function pointers, which I assume the linker sets up).
When running my own application, the _initterm function is also correctly
called, but it never calls the PROJ static constructors.
I use Visual Studio 2019, and I have carefully checked and compared compiler
and linker options between the test suite and my application and have not
found anything that can explain this.
I wonder if any of the people who have contributed the test suite may have
any ideas as to why this happens?
Thanks in advance for any help.
Finn Arildsen
Denmark
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200408/9cdd6ebe/attachment.html>
More information about the PROJ
