[PROJ] Understanding dropped parameters for stere and latlong
Even Rouault
even.rouault at spatialys.com
Sun Apr 12 12:50:04 PDT 2020
David,
> I noticed that the `lat_ts` parameter gets dropped for any case where
> `lat_0` isn't -90 or 90. Is this expected?
Yes. Given what is supported in the mathematical part of PROJ, either you have Polar
Stereographic (lat_0=+/-90, and lat_ts), or Oblique Stereographic (lat_0 != +/-90, and k_0)
Previous PROJ versions might have returned the string you provided, but that didn't mean all
the parameters you specified were taken into account.
> Is it no longer valid (or maybe it never was) to specify a "lon_0" for a
> lat/lon projection:
> crs = CRS("+proj=latlong +lon_0=45")
> crs.to_wkt()
> # Outputs:
> 'GEOGCRS["unknown",DATUM["World Geodetic System 1984",ELLIPSOID["WGS
> 84",6378137,298.257223563,LENGTHUNIT["metre",1]],ID["EPSG",6326]],PRIMEM["Gr
> eenwich",0,ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8901]],CS[ellips
> oidal,2],AXIS["longitude",east,ORDER[1],ANGLEUNIT["degree",0.017453292519943
> 3,ID["EPSG",9122]]],AXIS["latitude",north,ORDER[2],ANGLEUNIT["degree",0.0174
> 532925199433,ID["EPSG",9122]]]]'
There's no way in standard WKT to express a longitude of origin != 0 for a GeographicCRS. If
you export to WKT1_GDAL, a EXTENSION[] node captures this however. Or if you re-export
back to PROJ string the CRS object built from "+proj=latlong +lon_0=45", you'll get back the
original string.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200412/2566a717/attachment.html>
More information about the PROJ
