[PROJ] Understanding dropped parameters for stere and latlong
Martin Desruisseaux martin.desruisseaux at geomatys.com
Sun Apr 12 15:10:14 PDT 2020
Why not using PRIMEM, for example like below?
    GEODCRS["WGS 84 (anti-meridian)",
       DATUM["World Geodetic System 1984",
         ELLIPSOID["WGS 84", 6378137, 298.257223563, LENGTHUNIT["metre",1.0]]],
       PRIMEM["Anti-meridian", 180, ANGLEUNIT["degree",0.01745329252]],
       CS[ellipsoidal,2],
         AXIS["latitude",north,ORDER[1]],
         AXIS["longitude",east,ORDER[2]],
It should create a CRS with longitude in -180 to 180° range, but where
0° is at 180° from Greenwich (I not sure if this is what you wanted).
Martin
Le 12/04/2020 à 23:53, David Hoese a écrit :
> >There's no way in standard WKT to express a longitude of origin != 0
> for a GeographicCRS. If you export to WKT1_GDAL, a EXTENSION[] node
> captures this however. Or if you re-export back to PROJ string the CRS
> object built from "+proj=latlong +lon_0=45", you'll get back the
> original string.
> So if I use WKT2 as my standard in-memory/serialized version of a CRS,
> is there any standard way to handle a geotiff that goes over the
> anti-meridian (-180/180)? In the past I've played around with `+over`
> or changing with `+lon_0=X`, but those won't work here it seems.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200413/883a8fdc/attachment.html>
More information about the PROJ mailing list
