[PROJ] Why do I have a exception: NoSuchAuthorityCodeException?
Even Rouault
even.rouault at spatialys.com
Fri Apr 17 07:38:25 PDT 2020
On jeudi 16 avril 2020 14:21:46 CEST Евгений Соболев wrote:
> Hi.
> I use function proj_create_crs_to_crs for create PJ* for transform:
> C = proj_context_create();
> char** paths = new char*[1];
> QString pathapp = QApplication::applicationDirPath()+ "/proj4_data" ;
> paths[0] = _strdup(pathapp.toUtf8().constData());
> proj_context_set_search_paths(C, 1, paths);
> P = proj_create_crs_to_crs(C, "EPSG:4326", "EPSG:4923", NULL);
> I have exception: osgeo::proj::io::NoSuchAuthorityCodeException.
You mean that proj_create_crs_to_crs() throws a C++ exception that is propagated down
though your code ? That shouldn't happen, as at the worse case they are caught by
proj_create_crs_to_crs() itself. Or there's something really wrong with your build (or some
situations like
https://github.com/OSGeo/gdal/issues/2394 where a third-party library messes up with
libstdc++)
But, internally, indeed proj_create_crs_to_crs(C, "EPSG:4326", "EPSG:4923", NULL) will at
some point try to instanciate a projectedCRS and throw an exception, but it will be caught
immediately by other PROJ code, so you shouldn't worry about that.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200417/cc42107f/attachment-0001.html>
More information about the PROJ
