[PROJ] Vector/SIMD acceleration
Joris Van den Bossche
jorisvandenbossche at gmail.com
Fri Apr 17 12:49:18 PDT 2020
Another potential interesting project regarding SIMD is xsimd:
https://github.com/xtensor-stack/xsimd
On Fri, 17 Apr 2020 at 21:36, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 17 avril 2020 13:29:17 CEST Charles Karney wrote:
> > I wonder whether it's possible to get the benefits of vectorization
> > without massive of changes to the code.
> That's exactly what I had in mind.
> > Perhaps the basic projection
> > functions could be templated to allow Eigen arrays of PJ_LP's to be
> > passed. Eigen already has overloads for componentwise arithmetic
> > operations and handles SIMD vectorization automatically.
> I didn't know Eigen, but from a quick look & try, it seems I've done
> something similar.
> At least for types like Vector2d, Vector4d. But Eigen is quite limited in
> the operations it supports. Just +, -, *, /. No comparisons, sqrt, sin,
> cos, etc.
> Which my prototype supports (through sleef for sin, cos, etc).
> Adding support for functions that take Eigen types, like sqrt(Vector4d)
> should be possible, but comparison operators require to be able to modify
> the class definition.
> Another pain point I found with Eigen, is that it refuses to do things like
> a * b on vectors because of potential ambiguity of the operator in the
> context of linear algebra (matrix multiplication, cross product,
> member-to-member multiplication ?). But in a PROJ world where we'd port
> from double to multiple-double, we just want member-to-member
> multipication, and with Eigen you have to do it explictly with
> a.cwiseProduct(b). Would require more changes and would clutter the
> readability of the code.
> > A major advantage of this approach is that PROJ doesn't need to get into
> > the weeds with SIMD instructions. So when a new instruction set comes
> > along we can (I hope) rely on the maintains of Eigen to do the hard
> > work. (I see that there's already some interoperability with Eigen and
> > CUDA.)
> Admitedly I've only prototyped SSE and AVX. But supporting other archs
> would only require to add a specialization in the generic template stuff
> (not a big deal. It is of the order of 10 intrinsincs per arch), not
> projection code. And for non-supported archs, the templated operations
> would just expand to a 1-coordinate at a time implementation, like the
> current serial code. But I guess if Intel is covered, we have already > 90%
> use cases that matter (nobody ever paid me to optimize something for
> non-Intel archs).
> One potential downside (in the context of PROJ licencing) of Eigen is its
> license. It is MPL 2, weak copyleft, which would require binary
> distributions of PROJ to provide a way of accessing Eigen source code. Not
> a huge deal, but this would put additional requirements for proprietary
> shops using PROJ.
> > If this approach is followed, I would also recommend that the basic
> > floating point type, double, be either templated or typedef'ed.
> Yep, exactly my idea of template<typename T, int N> struct VF
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200417/1f30f2b8/attachment.html>
More information about the PROJ
