[PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
Thomas Knudsen
knudsen.thomas at gmail.com
Thu Apr 30 08:32:17 PDT 2020
+1 Thomas
Den tor. 30. apr. 2020 kl. 11.23 skrev Kristian Evers <kreve at sdfe.dk>:
> With the exception of a few minor warnings in 6.3.2RC1 reported by Greg,
> no serious problems have been found in the two release candidates.
> So, I hereby motion that we promote proj-7.0.1RC1 and proj-6.3.2RC1 to
> their final
> versions.
> I’ll start with my +1
> /Kristian
> -----Original Message-----
> From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Kristian Evers
> Sent: 27. april 2020 11:23
> To: PROJ <proj at lists.osgeo.org>
> Subject: [PROJ] PROJ 7.0.1RC1 & 6.3.2RC1
> All,
> With scheduled releases of PROJ 7.0.1 and 6.3.2. on May 1st it is time
> to put out release candidates. Both candidates includes a number of bug
> fixes since the previous release. 7.0.1 includes 39 bug fixes and 16 bugs
> has been fixed in 6.3.2. See the release notes below.
> Archives are available here:
> http://download.osgeo.org/proj/proj-7.0.1RC1.tar.gz
> http://download.osgeo.org/proj/proj-7.0.1RC1.zip
> http://download.osgeo.org/proj/proj-6.3.2RC1.tar.gz
> http://download.osgeo.org/proj/proj-6.3.2RC1.zip
> Please test the release candidates and report back any problems you
> may encounter.
> If no issues are found with the two release candidates the final releases
> will be announced on Friday May 1st.
> /Kristian
> 7.0.1 Release Notes
> Updates
> o Database: update to EPSG v9.8.9 #2141
> Bug fixes
> o Make tests independent of proj-datumgrid (#1995)
> o Add missing projection property tables (#1996)
> o Avoid crash when running against SQLite3 binary built with
> -DSQLITE_OMIT_AUTOINIT (#1999)
> o createOperations(): fix wrong pipeline generation with CRS that has
> +nadgrids=
> and +pm= (#2002)
> o Fix bad copy&replace pattern on HEALPix and rHEALPix projection names
> (#2007)
> o createUnitOfMeasure(): use full double resolution for the conversion
> factor (#2014)
> o Update README with info on PROJ-data (#2015)
> o utm/ups: make sure to set errno to PJD_ERR_ELLIPSOID_USE_REQUIRED if
> es==0 (#2045)
> o data/Makefile.am: remove bashism (#2048)
> o ProjectedCRS::identify(): tune it to better work with ESRI WKT
> representation of EPSG:2193 (#2059)
> o Fix build with gcc 4.8.5 (#2066)
> o Autotools/pkg-conf: Define datarootdir (#2069)
> o cs2cs: don't require +to for '{source_crs} {target_crs} filename...'
> syntax (#2081)
> o CMake: fix bug with find_package(PROJ) with macOS (#2082)
> o ESRI WKT import / identification: special case for
> NAD_1983_HARN_StatePlane_Colorado_North_FIPS_0501 with Foot_US unit
> (#2088)
> (#2089)
> o EngineeringCRS: when exporting to WKT1_GDAL, output unit and axis
> (#2092)
> o Use jtsk03-jtsk horizontal grid from CDN (#2098)
> o CMake: prefer to use use PROJ_SOURCE_DIR and PROJ_BINARY_DIR (#2100)
> o Fix wrong grids file name in esri.sql (#2104)
> o Fix identification of projected CRS whose name is close but not strictly
> equal to a ESRI alias (#2106)
> o Fix working of Helmert transform between the horizontal part of
> 2 compoundCRS (#2111)
> o Database: fix registration of custom entries of
> grid_transformation_custom.sql
> for geoid grids (#2114)
> o ESRI_WKT ingestion: make sure to identify to non-deprecated EPSG entry
> when
> possible (#2119)
> o Make sure that importing a Projected 3D CRS from WKT:2019 keeps the base
> geographic CRS as 3D (#2125)
> o createOperations(): improve results of compoundCRS to compoundCRS case
> (#2131)
> o hgridshift/vgridshift: defer grid opening when grid has already
> been opened (#2132)
> o Resolve a few shadowed declaration warnings (#2142)
> o ProjectedCRS identification: deal with switched 1st/2nd std parallels
> for
> LCC_2SP(#2153)
> o Fix Robinson inverse projection (#2154)
> o createOperations(): do not remove ballpark transformation if there are
> only
> grid based operations, even if they cover the whole area of use (#2156)
> o createFromCoordinateReferenceSystemCodes(): 'optimization' to avoid
> using
> C++ exceptions (#2161)
> o Ingestion of WKT1_GDAL: correctly map 'Cylindrical_Equal_Area' (#2167)
> o Add limited support for non-conformant WKT1 LAS COMPD_CS[] (#2172)
> o PROJ4 string import: take into correctly non-metre unit when the string
> looks like the one for WGS 84 / Pseudo Mercator (#2177)
> o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2184)
> o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2186)
> 6.3.2 Release Notes
> Bug fixes
> o validateParameters(): fix false-positive warning on
> Equidistant Cylindrical (#1947)
> o proj_create_crs_to_crs(): avoid potential reprojection failures when
> reprojecting area of use to source and target CRS (#1993)
> +nadgrids=
> and +pm= (#2003)
> (#2006)
> factor (#2013)
> o data/Makefile.am: remove bashism (#2047)
> representation
> of EPSG:2193 (#2058)
> (#2091)
> o Add missing entries in grid_alternatives for Portugal grids coming from
> ESRI entries (#2103)
> o Fix working of Helmert transform between the horizontal part of 2
> compoundCRS (#2110)
> when
> possible (#2118)
> geographic CRS as 3D (#2124)
> (#2130)
> looks
> like the one for WGS 84 / Pseudo Mercator (#2178)
> o Fix support of WKT1_GDAL with netCDF rotated pole formulation (#2187)
> o io.hpp: avoid dependency to proj_json_streaming_writer.hpp (#2188)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200430/9076ce4f/attachment-0001.html>
More information about the PROJ
