[PROJ] Problem converting to State Plane Coordinates
wayne at truwayllc.com wayne at truwayllc.com
Tue Aug 11 16:43:42 PDT 2020
Hello,
I just compiled proj 7.1.0 on my machine and the examples I’ve tried from the Proj website seem to work. I’m trying to convert from Lat/Long coordinates to State Plane zone 4302 (Central Utah). After a bit of searching I found what appears to be the correct syntax to enter the state plane zone "+nad83:4302”. I tried starting with a simplified set of arguments as follows...
$ echo -111.4342412778 40.6680408972 | proj +proj=utm +nad83:4302 +ellps=WGS84
-5286420.10	12245588.21
The expected result (from a tie sheet) is 505560.312 2259209.082
If I Try the same syntax to translate to UTM zone 12 I get a more reasonable result
$ echo -111.4342412778 40.6680408972 | proj +proj=utm +zone=12 +ellps=WGS84
463296.98	4501998.16
What am I doing wrong here?
I would be particularly interested in seeing how to do this with the more modern PROJ pipeline syntax.
Thanks,
Wayne Anderson
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200811/7461c828/attachment.html>
More information about the PROJ mailing list
