[PROJ] How to map pj_latlong_from_proj to PROJ ver 7 API
Even Rouault even.rouault at spatialys.com
Tue Dec 1 07:21:40 PST 2020
On mardi 1 décembre 2020 12:00:23 CET Pierluigi Guasqui wrote:
> proj_get_source_crs
You can use my hints about using proj_get_source_crs() and then you can get
the PROJ string for it with proj_as_proj_string(). Note however that using
PROJ strings to represent CRS is a suboptimal / deprecated way in some
situations. You'd be much better with WKT for example.
http://www.spatialys.com
More information about the PROJ mailing list
