[PROJ] Alternate use model on EPSG v10+ datum ensembles
Even Rouault
even.rouault at spatialys.com
Thu Dec 17 05:54:30 PST 2020
Jack,
> There is one example in the v10 EPSG registry that demonstrates this
> alternate use model definition (datum members with mutually-exclusive
> extents), with vertical and compound CRSs, but no associated coordinate
> operations defined as of yet:
> Datum: British Isles height ensemble, EPSG Code 1288
> https://epsg.org/datum_1288/British-Isles-height-ensemble.html
That's a good point, but the use of a datum ensemble to model this is quite
surprising to me. According to ISO-19111:2019, a datum ensemble is a "group of
multiple realizations of the same terrestrial or vertical reference system
that, for approximate spatial referencing purposes, are not significantly
different". One consequence of that would seem that all members of a same
ensemble should have the same extent (otherwise if you use a 'random' member
and its extent is not compatible with your point of interest, it is
significantly different...). I'll raise the matter to EPSG.
> This vertical CRS/datum
> ensemble would then be used to define a compound CRS (e.g., geog2D
> NAD83(2011) + 'NOAA Chart depth'), and a coordinate operation would be
> defined to transform to/from (reversible) between that and a geog3D CRS.
> This transform involves one or more (if a multi-step operation) sets of
> gridded transforms in a 1:1 relationship with the extents of the ensemble
> members. The idea being that proj would have to do the heavy lifting of
> point-by-point spatial tests per the defined extents in the metadata.
> Does this make sense and is it feasible?
For the case where it is a single step operation, you would have to define
either one transformation for each grid (a bit like the records for GEOID99
where CONUS was split in 8 grids), or have a single transformation pointing to
a single file made of several grids (PROJ's GeoTIFF TIFF Grids allow this).
There's no method in EPSG where, for a given transformation, you can provide
an arbitrary list of grids that wouldn't have the same extent (and that would
make it inefficient for PROJ, or any other software, since you'll have to open
each grid to figure out if its extent contains the point to transform)
I'm not sure if it makes sense to define the individual datums without
associated CRS. As far as I can see in EPSG, there's just one case where this
happens with the vertical datum EPSG:5107 that has no corresponding CRS, but
that datum is deprecated. But the introduction of the datum ensemble concept
might perhaps change this.
Even
http://www.spatialys.com
More information about the PROJ
