[PROJ] 7.2.1 RC1 ob_tran changes break existing logic
Kristian Evers
kristianevers at gmail.com
Mon Dec 28 02:33:50 PST 2020
… and with cs2cs I get your expected result:
$ echo 9.05 48.52 |PROJ_LIB=./data/ ./src/cs2cs -f %.6f "+proj=ob_tran +o_proj=longlat +o_lon_p=-162 +o_lat_p=39.25 +lon_0=180 +ellps=sphere +no_defs +type=crs" +to "proj=longlat +type=crs"
-5.917698 -1.871950 0.000000
I reckon there’s a bit of fine-tuning needed in your test suite. My best guess is adding “+type=crs” to the projstrings.
/Kristian
> On 28 Dec 2020, at 11:26, Kristian Evers <kristianevers at gmail.com> wrote:
> I can reproduce the pipeline you expect using the below call to projinfo, but it is unclear to me if your code is doing something similar behind the scenes. That is, using the projstring as a CRS definition in a transformation from the ob_tran “CRS” to a latlong CRS. Note that I’ve added “+type=crs” arguments to both projstrings to let projinfo know that these are legacy PROJ.4 CRS definitions.
> $ PROJ_LIB=./data/ ./src/projinfo -s "+proj=ob_tran +o_proj=longlat +o_lon_p=-162 +o_lat_p=39.25 +lon_0=180 +ellps=sphere +type=crs" -t "proj=longlat +type=crs" -o PROJ
> Candidate operations found: 1
> Operation No. 1:
> unknown id, Inverse of unknown + Ballpark geographic offset from unknown to unknown, unknown accuracy, World, has ballpark transformation
> PROJ string:
> +proj=pipeline
> +step +proj=unitconvert +xy_in=deg +xy_out=rad
> +step +inv +proj=ob_tran +o_proj=longlat +o_lon_p=-162 +o_lat_p=39.25
> +step +proj=unitconvert +xy_in=rad +xy_out=deg
> /Kristian
>> On 28 Dec 2020, at 11:10, Kristian Evers <kristianevers at gmail.com> wrote:
>> Roger,
>> Thanks for reporting this. We certainly need to find out what’s going on here. It is possible that this change shouldn’t have been included in 7.2.1.
>> I can’t fully understand what you are trying to do from your code snippet below, can you provide an example that only uses PROJ tools or API?
>> /Kristian
>>> On 28 Dec 2020, at 10:18, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> News item:
>>> createOperation(): make it work properly when one of the CRS is a BoundCRS of a DerivedGeographicCRS (+proj=ob_tran +o_proj=lonlat +towgs84=....) (#2441)
>>> appear to break:
>>> (crds <- matrix(data=c(9.05, 48.52), ncol=2))
>>> (a <- project(crds, paste("+proj=ob_tran +o_proj=longlat",
>>> "+o_lon_p=-162 +o_lat_p=39.25 +lon_0=180 +ellps=sphere +no_defs"),
>>> use_ob_tran=TRUE, verbose=TRUE))
>>> stopifnot(isTRUE(all.equal(a, matrix(c(-5.917698, -1.87195), ncol=2),
>>> tolerance=.Machine$double.eps ^ 0.25)))
>>> completely in the R rgdal package. ob_tran has always needed special casing, because of the reverse invert direction, but this change is a major regression. The operation on input 9.05 48.52 should return -5.917698 -1.87195 but now chooses coordOp: +proj=noop +ellps=GRS80. In
>>> 7.2.0, the chosen coordOp is (and probably should be):
>>> +proj=pipeline +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +inv +proj=ob_tran +o_proj=longlat +o_lon_p=-162 +o_lat_p=39.25 +lon_0=180 +ellps=sphere +step +proj=unitconvert +xy_in=rad +xy_out=deg
>>> The NEWS item does not lead one to expect this regression.
>>> Hope some light can be thrown on this and that release will not be rushed.
>>> Best wishes,
>>> Roger
>>> Roger Bivand
>>> Department of Economics, Norwegian School of Economics,
>>> Helleveien 30, N-5045 Bergen, Norway.
>>> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
>>> https://orcid.org/0000-0003-2392-6140
>>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>>> PROJ mailing list
>>> PROJ at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/proj
>> PROJ mailing list
> PROJ mailing list
More information about the PROJ
